Author Topic: JK/JKU rear axles for Rubicon D44  (Read 145 times)
Offline tomjones20194
  • Member 2017
« on: October 29, 2017, 12:01:09 PM »
Axles in good condition. Splines are perfect. Needs driver side axle seal replaced (it leaks). Great set to keep as trail spares. Or replace the seal if you have access to a bearing press. $50
1979 CJ-5 Renegade Levi Edition (360 V8)
2008 Wrangler Unlimited Rubicon
Powered by EzPortal
President: Jeremy Long (JK_HVGC) | Vice President: John Davis (jdavis2nd) | Secretary: James Wesolek (sirjames186)
Treasurer: Danille Wilson (TJ Girl) | Member-at-large: Alex Zaiken (z4iken)
Jason Markvart (LNDSRK) | Steve Scott (Islander90) | Josh Storer (Jastor)| Mike Finelli (BiggMike) | John Harper (Opie)
All images from NoVaJeepers.net are exclusive to the Northern Virginia Jeepers Association. Any reproduction of exclusive Northern Virginia Jeepers Association material is strictly prohibited without written consent of the Northern Virginia Jeepers Association.
Materials are copyright Northern Virginia Jeepers Association 2002-2018.
