Author Topic: ** Fort Wayne - Wrangler Double Cardan CV Front Driveshaft 97-02 **  (Read 263 times)
Offline DRTY-DS
  • Member 2017 VA4WD
  • 99 TJ Sport 4.0L
https://washingtondc.craigslist.org/nva/pts/d/fort-wayne-jeep-wrangler/6405192263.html
Let me know if you have any question. Thanks for looking!
Offline schreiberaj
  • Member 2017
Re: ** Fort Wayne - Wrangler Double Cardan CV Front Driveshaft 97-02 **
« Reply #1 on: December 15, 2017, 10:11:11 AM »
Was this on a manual or automatic? Mind posting up the collapsed and extended lengths from the center of the U-joint?
Offline DRTY-DS
  • Member 2017 VA4WD
  • 99 TJ Sport 4.0L
« Reply #2 on: December 18, 2017, 11:20:37 AM »
It was installed on standard. Told it will work with either given the connection to the TC is the same. To ensure proper application for your rig, I would recommend and encourage you to contact the manufacture. Don't want to give you bad info. What I can tell you is that worked with our 6 inch with D30LP, however, we felt a vibration at higher speeds. Took to Drive line specialist in Lorton. They told it was short for our application. So i had they build one specifically for our rig. Hope this info helps. Let me know if you have any other questions. Thanks for interest! John
Offline schreiberaj
  • Member 2017
« Reply #3 on: December 18, 2017, 12:53:29 PM »
You are correct in the fact that the same transfer case allows it to be mated however there is a difference in lengths between auto and manual driveshafts because of the different transmissions. I think 97-99 standard/manual could have had either the AX-15 or AX-5 while the auto was a 32RH for those years. The CL link is dead so if you could measure from center yoke to center yoke or just post the make/model/year it came off of then I can probably google the stock length.
Offline DRTY-DS
  • Member 2017 VA4WD
  • 99 TJ Sport 4.0L
« Reply #4 on: December 18, 2017, 01:03:40 PM »
My bad. You're correct. AX-15 Trans w/ NV-231 TC. Appreciate the heads on CL link.... https://washingtondc.craigslist.org/nva/pts/d/fort-wayne-jeep-wrangler/6425578190.html
In the interim, here's the manufactures link... http://fortwayneclutch.com/product/19972002-jeep-wrangler-front-double-cardan-cv-style-propeller-driveshaft-assembly-skus-922204-2524-52098377ad-p52098377ad-919374-2521/
Was installed in a 99 TJ. D30 LP. Hope this helps.
Powered by EzPortal
President: Jeremy Long (JK_HVGC) | Vice President: John Davis (jdavis2nd) | Secretary: James Wesolek (sirjames186)
Treasurer: Danille Wilson (TJ Girl) | Member-at-large: Alex Zaiken (z4iken)
Jason Markvart (LNDSRK) | Steve Scott (Islander90) | Josh Storer (Jastor)| Mike Finelli (BiggMike) | John Harper (Opie)
All images from NoVaJeepers.net are exclusive to the Northern Virginia Jeepers Association. Any reproduction of exclusive Northern Virginia Jeepers Association material is strictly prohibited without written consent of the Northern Virginia Jeepers Association.
Materials are copyright Northern Virginia Jeepers Association 2002-2018.
